Help restoring plex scheduled task database
I was manipulating my plex movie libraries and screwed up my database when I repointed my movie collection to my TV collection instead.
I tried to follow the following instructions to restore my database, but unfortunately, when I restored the database, it looked fine (I.e. the way it did before I messed up), but I can’t play media, and if I go to settings, I get a “Server settings are unavailable.”
I also tried to restor the com.plexapp.plugins.library.blobs.db from the same backup.
I am on ubuntu.
HELP!!!
Would need server logs after restarting the server - hopefully you have not disabled debug logging - if you have then would need to edit Preferences.xml
may be permissions are wrong now
See this support article for location of logs
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
You’re right! I forgot that plex uses plex:plex vs user that was used to install!
Changing ownership on the two .db files fixed the issue! Would be good to note that in wiki!
