I’m having a nightmare with plex at the minute, its one problem after another and haven’t had a stable plex for weeks. I had the dreaded media server cant be restarted numerous times forcing a full factory reset on my Nvidia Shield 2017 (still no solution to why this happens) and now i have a message on some libraries, not all, that says unexpected error loading this library. Cannot find a solution online despite lots of people having the same issue. Can only find old posts but no resolution. It seems that a factory reset wont even solve this one. Can anyone help? To note some libraries that share the same drive are working and some are not. I’ve tried refreshing database, optimising, emptying trash, bundles, every option possible but still not working. I’m so sick of plex at the minute, why can’t it just work! When it does it’s great!
Also noticed when on the Nvidia the libraries are showing no content but the home is showing recently added etc and i can play these films no problem. However through the webapp the libraries show only in home and in library but not in recommended, but i can’t play any of the files on the webapp aside from 2 of libraries, tv shows and stand up, even the ones in home don’t play through the webapp but they do on the Nvidia.
Thanks in advance
D
