Help with a home screen setup
Hi, I am usado Plex server Version 4.136.1 with my movie library and I could use some help with a home screen configuration. How can I configure the home screen so that only continue to watch and unseen titles are displayed.
In the various settings I have not found anything with the words “unseen titles” that I can set.
Thank you for your help
Aurelio
You should be able to configure which hubs of a library are displayed on the Home Screen by selecting from the available options (or unchecking the ones you don’t want to see).
Settings > [Server Name] > Manage > Libraries
https://support.plex.tv/articles/manage-recommendations/
In case there’s more options, you can also create your own hubs by „publishing“ a collection to the Home Screen (e.g. a smart collection listing all unwatched movies of a library, sorted by date added… optionally limited to just the last X items of items added during a specific period…).
https://support.plex.tv/articles/publishing-collections/
Hi, it’s not that simple, I couldn’t do it.
In the library management section there is a best unseen movies option, I tried that and by applying movies to be seen to the movie itself, in the house it would seem to work in part, that is, some movies it puts them in the house and some it doesn’t, and I don’t know why.
But why complicate things, it would be enough that in the library management section there would be an option unseen movies and through the check mark as unseen to the movie, he puts it in the house.
Aurelio
