Help with accessing movie library on Smart TV
I haven’t used PLEX much in the past and I’m curious to learn if it can help me access my movie library.
My current setup is as follows:
  • Samsung Smart TV from 2018 with the PLEX-app installed.
  • iPhone 8
  • iPad Pro with Plex installed
  • Apple TV 3rd Gen
  • USB-drive with all my movies and tv-shows ripped from DVDs some years ago, when I had a Mac.
As it is now, I can access all those ripped movies and TV shows by plugging in that USB-drive to my iPad Pro.
Then I can use my AppleTV 3rd gen. to play that movie or tv show on my Samsung TV.
But what I want to learn is, if there is a better, faster and easier way to access my the media library on that USB-drive, perhaps using PLEX, or some other way?
Plex works by streaming your files from a central server that you set up on your network. You’ll need something like a Mac or a NAS to do this, something that will run the Plex Media Server (PMS) software. The files that PMS can access can then be streamed to other Plex apps.
Alright, thanks! I’m not really in the mood for adding a NAS and I’m completely off the Mac. I only use an iPad Pro, iPhone, Apple TV and HomePod.
So PLEX doesn’t work similarly to iTunes Match, which I originally thought, right?
I upload all my movies and tv shows from my USB drive to your servers and then I can access it on any device. I need to store it locally in my house to be able to play it?
Correct. Plex is no a cloud service.
