mind sharing some more details?
e.g. what’s the specific setup when it comes to playing that 4K HDR… media? If the server is running on your Shield Pro – do you play the media from a TV that’s connected to the Shield via HDMI or on a different device (e.g. streaming box connected to a different TV, PC, mobile…)?
You mention a PC… is that where you try to play that video?
The server and media (typically mkv) is on a windows pc. Streams direct play to the shield pro and then goes via 8k certified hdmi cable to a Yamaha 585 and then eARC to an LG oled C9.
Are you sure its buffering? Watch your Plex dashboard when it happens, I’ve been complaining of an issue where the dashboard shows my stream as paused, not buffering. It just looks like buffering on the client
Mine flips between paused and playing. Makes it look like buffering. I’d be curious what you see
Nope, ever since I did that network reset it’s been flawless, so I guess that was my solution for anyone with a mesh network like mine. I did upgrade all the cables to cat8 in the process but I’m pretty sure that wasn’t it as it started working pre cable upgrade.
