Good morning,
I just did my first Linux install of PMS having previously run this on Windows. The PC I am using is a Dell 9010 which has an i7-3770 processor onboard. I have added an NVIDIA Quadro P620 to help with transcoding.
The bios for my machine only allows me to select which of the graphics cards will be primary (I have selected the NVIDIA).
When I am doing hardware transcoding it is defaulting to the intel integrated chipset which is confirmed in the logs.
transcodeHwDecoding=“vaapi” transcodeHwEncoding=“vaapi” transcodeHwDecodingTitle=“Intel (VA API)” transcodeHwEncodingTitle=“Intel (VA API)” transcodeHwFullPipeline=“1”>
I can see the usage on the intel GPU when I look at the monitor tools.
Nvidia-SMI confirms the card drivers are loaded correctly:
| NVIDIA-SMI 430.14 Driver Version: 430.14 CUDA Version: 10.2 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 Quadro P620 Off | 00000000:01:00.0 Off | N/A |
| 43% 51C P0 N/A / N/A | 0MiB / 1999MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
I am at a loss as far as how I get the plex transcoder to use the nVidia card instead of the integrated graphics.
Any help would be greatly appreciated.
Thanks in advance.
any other ideas?
