Server Version#: 3.102…0
Player Version#: ???
All, I’m having issues getting trying to get this movie to Direct Play. I’ve seen in other posts for other clients where the order of audio tracks might be influencing the server’s decision to transcode, but I can’t find any concrete evidence of what the root cause is. Could someone check out this excerpt from my logs and point me in the right direct?
Also - When the movie is playing, the audio reports as direct stream (aac), the video is transcoding 4k (h.264 HDR) to 1080P (h264).
Jun 17, 2019 12:43:14.725 [0x7f78a1683700] DEBUG - It took 0.000000 ms to retrieve 113 items.
Jun 17, 2019 12:43:14.726 [0x7f78a1683700] DEBUG - We’re going to try to auto-select an audio stream for account 1.
Jun 17, 2019 12:43:14.726 [0x7f78a1683700] DEBUG - Selecting best audio stream for part ID 34701 (autoselect: 0 language: en)
Jun 17, 2019 12:43:14.726 [0x7f78a1683700] DEBUG - Audio Stream: 38594, Subtitle Stream: -1
Jun 17, 2019 12:43:14.727 [0x7f78a1683700] DEBUG - We’re going to try to auto-select an audio stream for account 1.
Jun 17, 2019 12:43:14.727 [0x7f78a1683700] DEBUG - Selecting best audio stream for part ID 34814 (autoselect: 0 language: en)
Jun 17, 2019 12:43:14.727 [0x7f78a1683700] DEBUG - Audio Stream: 38832, Subtitle Stream: -1
Jun 17, 2019 12:43:14.728 [0x7f78a1683700] DEBUG - Codecs: testing h264_nvenc (encoder)
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] ERROR - [FFMPEG] - libva: va_getDriverName() failed with unknown libva error,driver_name=(null)
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/output error
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - Scaled up video bitrate to 27600Kbps based on 1.500000x fudge factor.
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - Scaled maximum bitrate for resolution reduction to 6900Kbps.
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - MDE: Selected protocol hls; container: mpegts
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - MDE: analyzing media item 34751
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - MDE: The Hunger Games: Mockingjay - Part 1 (2014): Direct Play is disabled
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - MDE: The Hunger Games: Mockingjay - Part 1 (2014): media must be transcoded in order to use the hls protocol
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - MDE: The Hunger Games: Mockingjay - Part 1 (2014): no direct play video profile exists for http/mp4/h264
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - MDE: The Hunger Games: Mockingjay - Part 1 (2014): no direct play video profile exists for http/mp4/h264/aac
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - MDE: The Hunger Games: Mockingjay - Part 1 (2014): no direct play video profile exists for http/mp4/h264/ac3
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - The Hunger Games: Mockingjay - Part 1 - video.width limitation applies: 3840 > 1920
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - MDE: The Hunger Games: Mockingjay - Part 1 (2014): no remuxable profile found, so video stream will be transcoded
Jun 17, 2019 12:43:14.905 [0x7f78a1683700] DEBUG - Codecs: testing h264_nvenc (encoder)
Jun 17, 2019 12:43:15.067 [0x7f78a1683700] DEBUG - The Hunger Games: Mockingjay - Part 1 - video.width limitation applies: 3840 > 1920
Jun 17, 2019 12:43:15.067 [0x7f78a1683700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Jun 17, 2019 12:43:15.067 [0x7f78a1683700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Jun 17, 2019 12:43:15.067 [0x7f78a1683700] ERROR - [FFMPEG] - libva: va_getDriverName() failed with unknown libva error,driver_name=(null)
Jun 17, 2019 12:43:15.067 [0x7f78a1683700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Jun 17, 2019 12:43:15.067 [0x7f78a1683700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/output error
Jun 17, 2019 12:43:15.067 [0x7f78a1683700] DEBUG - Scaled up video bitrate to 27600Kbps based on 1.500000x fudge factor.
Jun 17, 2019 12:43:15.067 [0x7f78a1683700] DEBUG - Scaled maximum bitrate for resolution reduction to 6900Kbps.
