If you look at the keyboard, on the front side, it has a fast forward and rewind buttons on the top left corner, but they didn't work out of the box with plex / rasplex.
So I enabled the debug logging on plex, and looked to see which buttons it was mapping to.Now, I'm just unable to map those two keys.
Can you login via SSH and type irw and then press each of the buttons and post results back here indicating which is which. Control C will get you back out of irw.
Regards
Follow the guide and just create two entries, one for KEY_REWIND and one for KEY_FASTFORWARD (you could also create one for KEY_STOP using a spare button on the remote), when finished reboot and test.
Regards
I tried it and nothing happened.
The usb dongle probably only replies to the 2,4ghz wireless connection and not the IR.
