Help with My Media
Server Version#: 1.40.5.8921
I do not know how this works. Or if I am in the right place for help. But recently Windows forced an update, then Plex would not work, or at least it would not pull up My media. Finally I realized that I needed to download the latest Plex server (I downloaded 1.40.5.8921). It works for most things, like Movies and TV shows. But the other library’s I had that were for “Other videos” could be seen but I can no longer add anything to them. When I ask it to update, it doesn’t even spin like it is looking for anything. Please help me if you can.
Lets start with server logs, an example file name for something in the Other Library and the path to that library
I have downloaded the server logs and attached them.
Plex Media Server Logs_2024-09-01_16-52-44.zip (3.2 MB)
Thank you for any help. As i’v said, I can download a movie or TV show and put them in the path for the Plex server and they show up fine, but none of my Other Video librarys work, like: I have a library for my Grandson called “Everett Stuff” I have two locations where I put videos for him and they show up in Plex. But now I can not add anything to it. Nothing else will show up or even be searched for when I press “scan Library files.”
Plex is seeing the files and is indexing them,
Aug 20, 2024 19:40:37.349 [10096] DEBUG - Looking for path match for [I:\Media\Everett stuff\Barney
(censored the actual filename) But looks like you are mixing base folder and subfolder systems: I:\Media\Everett stuff\file.mp4 and I:\Media\Everett stuff\videoname\videoname.mp4 the first format can work, but is not recommended, and mixing the two can cause issues. What I would do is in plex delete the library, optimized the database, clean the bundles and then re-add the library.
I will try that. But I turned my computer off because a storm was coming. When I turned it back on again I can not access any of my media again. I already downloaded the latest server. Is there anything I can do to fix this? Thanks
What does http://[Local Plex Media Server IP Address]:32400/identity show?
I’m sorry, I don’t know what you are asking. Is this found some place?
I tried downloading the server again ( Version 1.40.5.8921) and it worked, I am able to see my media again. But if the computer is turned off again will this happen again?
