Hevc / h265 in surface go 2
Hello!
I want buy the new Surface go 2 at 400 dollars with Intel Pentium Gold 4425Y , but i would know if i can run Plex with a h265 / Hevc transcoding in full HD video 1080p and lower…, h264 ?
I have the Synology 918+ but i want made Direct play with this tablet like on my phone (Samsung Galaxy s8) so the tablet need to transcoding no?
I want this tablet because i can run in backgroup hue sync and have my little tablet with hue light ! It’s possible? any idea? i can install Plex and hue sync when i disable “windows 10 s” it’s a new things, now surface go 2 can run on windows 10 home.
So i Can install all windows apps
I watch on the web Intel Pentium gold 4425Y can “decode” and “encode” h265 10bit but he had enouth power to did it well in full HD? And if i add hue Sync ?
Intel Pentium gold 4425Y:
Frequency:1.60 GHz
CPU Cores:2
CPU Threads:4
Intel UHD 615
Ram 4gb
Storage: 64 gb
to give an idea, here it’s only a 720p video hevc and my actual computer have i5 and Hd graphics 620
(ram increase between 2 picture because i have Edge open on 2nd picture)
thanks for all replies
Sorry for my english. And thanks for your reply.
I only want watch my HEVC 1080p media on the surface go 2.
I have Synology 918+ with Plex media Server and he can transcoding h265 4k.
It’s possible to read my video on the surface go 2 with “Plex for Windows” ?
i only have to uncheck that?
Direct streaming? Direct play?
Thanks a lot!
Just to be sure, It dépend a lot on my files okay. But if its work on my smartphone and smart TV, they have lot or chance it work on surface go 2 no?
Thanks a lot trumpy81 (merci beaucoup lol)
I Will buy it and see.
Later i will post answer. Always Can be useful
PS: mais comment tu peux savoir que je suis français ?! Ça doit se voir dans mes messages lol
Yes. It Work fine, i Just try 30 minutes, launch HEVC 10bit and it Work fine!
For 4k HEVC 10bit forget! Not enouth perf. But we Can set HD 4Mb and it works perfect also with good quality.
After, it’s overkill to read 4k with full HD screen. But connect 4k vidéo screen on Plex don’t works with HEVC 10bit on this tablet.
But for 1080p, perfect !
After that i try to put hue sync and it Work also perfect in full HD.
Thanks for all
EDIT: If i put performance mod Maybe 4k works fine
No problem. I only read 1080p file, i Just have few 4k file to test.
Thanks for all your replies.
Picture IS beatiful on 4k, not “washed out” but picture seems have 10 fps (not 25).
