High bitrate media + 7.2.2 = endless buffering
Is anyone else seeing this too?
Do you really mean 7.2.2? That’s an old beta.
7.2.2 is the Nvidia shield software. I have the plex beta auto-update.
Ah ok. How high a bitrate are we talking? I have some 50-100 Mbps samples that I use for testing and haven’t noticed an issue. Can you provide the XML for your video that causes this?
It seems to be anything above a high bitrate like 30Mb…
It’s for every single video (that’s high bitrate) so I don’t think an xml won’t help. It’s easily reproducible.
Try and test it for any 30Mb file on a remote server.
Basically goes back to this post… There is some sort of latency/buffer check that seems to get triggered…
Just tested using the popular 40Mbps and 100Mbps jellyfish samples. They buffered since my connection isn’t fast enough, but they did load and play.
Please recreate and send me the log from PMS and the client so I can check which end the problem might be from.
Older log file sent via pm/dm.
Based on your description of the issue you provided, it’s not the same issue danjames92 is describing. For you, since it appear to occur at the same spot within a file, my guess is that there is a spike in the bitrate which may be too high for the Shield to handle. For example, if you have a file that is listed as having a bitrate of 50 Mbps, depending on how the file was created, there could be spikes 10x (or even more) that bitrate. So if you have a spike of 500Mbps for 1 second, that’s 60MB worth of data for 1 second of video. That might be too much for the Shield to handle.
The issue the OP is seeing could be related if the spike is occurring at the beginning of the file.
If this is the case, I’m not sure what we can do to fix this. The playback stack memory is only so large. I’m still checking your log to see if there is some other issue.
The SHIELD can playback uncompressed 4K from a remote server, it can handle the bitrate. This is likely a SHIELD firmware issue as it was not happening prior to 7.2.2.
So is your issue with high bitrate (30+ Mbps) hevc files?
Edit - What do you mean uncompressed?
No I was just stating that the SHIELD has zero problems managing files with extremely high bitrate like Remux 4K’s.
So what type of files are you having issues with? Why I asked for the XML.
Here’s a generic xml
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="2" librarySectionTitle="Movies - Remux" librarySectionUUID="76676e7c-bf16-4aaf-a21a-a49194ff6109"mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1544818278">
<Video ratingKey="10836" key="/library/metadata/10836" guid="com.plexapp.agents.imdb://tt0096734?lang=en" librarySectionTitle="Movies - Remux" librarySectionID="2" librarySectionKey="/library/sections/2" studio="Imagine Entertainment" type="movie" title="The 'Burbs" titleSort="'Burbs" contentRating="gb/PG" summary="When secretive new neighbors move in next door, suburbanite Ray Peterson and his friends let their paranoia get the best of them as they start to suspect the newcomers of evildoings and commence an investigation. But it's hardly how Ray, who much prefers drinking beer, reading his newspaper and watching a ball game on the tube expected to spend his vacation." rating="5.0" audienceRating="7.1" year="1989" tagline="He's a man of peace in a savage land... Suburbia." thumb="/library/metadata/10836/thumb/1544037364" art="/library/metadata/10836/art/1544037364"duration="6086390" originallyAvailableAt="1989-02-17" addedAt="1500821528" updatedAt="1544037364" audienceRatingImage="rottentomatoes://image.rating.upright" chapterSource="media" primaryExtraKey="/library/metadata/22101"ratingImage="rottentomatoes://image.rating.rotten">
<Media videoResolution="1080" id="22574" duration="6086390" bitrate="33353" width="1920" height="1080" aspectRatio="1.78" audioChannels="2" audioCodec="dca-ma" videoCodec="h264" container="mkv" videoFrameRate="24p"audioProfile="ma" videoProfile="high">
<Part accessible="1" exists="1" id="22574" key="/library/parts/22574/1500821528/file.mkv" duration="6086390" file="/data/Movies/Movies-Remux/The 'Burbs (1989)/The 'Burbs (1989) [Remux-1080p - X264 - 8bit - 2.0ch - DTS-HD MA - EPSiLON].mkv" size="25375205829" audioProfile="ma" container="mkv" videoProfile="high">
<Stream id="59556" streamType="1" default="1" codec="h264" index="0" bitrate="31817" language="English" languageCode="eng" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" colorPrimaries="bt709"colorRange="tv" colorSpace="bt709" colorTrc="bt709" frameRate="23.976" hasScalingMatrix="0" height="1080" level="41" profile="high" refFrames="4" scanType="progressive" title="MPEG-4 AVC Video / 31648 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1" width="1920" displayTitle="1080p (H.264)"/>
<Stream id="59557" streamType="2" selected="1" default="1" codec="dca" index="1" channels="2" bitrate="1536" language="English" languageCode="eng" audioChannelLayout="stereo" bitDepth="16" profile="ma"samplingRate="48000" title="DTS-HD Master Audio / 2.0 / 48 kHz / 1627 kbps / 16-bit" displayTitle="English (DTS-HD MA Stereo)"/>
<Stream id="59558" streamType="3" codec="pgs" index="2" bitrate="39" language="English" languageCode="eng" title="SDH" displayTitle="English (PGS)"/>
<Stream id="59559" streamType="3" codec="pgs" index="3" bitrate="42" language="Deutsch" languageCode="ger" displayTitle="Deutsch (PGS)"/>
<Stream id="59472" key="/library/streams/59472" streamType="3" codec="srt" language="Español" languageCode="spa" format="srt" displayTitle="Español (SRT External)"/>
<Stream id="59471" key="/library/streams/59471" streamType="3" codec="srt" language="Nederlands" languageCode="dut" format="srt" displayTitle="Nederlands (SRT External)"/>
</Part>
</Media>
<Genre id="77" filter="genre=77" tag="Comedy"/>
<Genre id="314" filter="genre=314" tag="Mystery"/>
<Genre id="315" filter="genre=315" tag="Thriller"/>
<Director id="35061" filter="director=35061" tag="Joe Dante"/>
<Writer id="87376" filter="writer=87376" tag="Dana Olsen"/>
<Producer id="99679" filter="producer=99679" tag="Larry Brezner"/>
<Producer id="73405" filter="producer=73405" tag="Michael Finnell"/>
<Country id="151" filter="country=151" tag="USA"/>
<Role id="6035" filter="actor=6035" tag="Tom Hanks" role="Ray Peterson" thumb="http://image.tmdb.org/t/p/original/xxPMucou2wRDxLrud8i2D4dsywh.jpg"/>
<Role id="15134" filter="actor=15134" tag="Bruce Dern" role="Lt. Mark Rumsfield" thumb="http://image.tmdb.org/t/p/original/lumA2Tb4YAfClkCRDCR0YrDimmF.jpg"/>
<Role id="3570" filter="actor=3570" tag="Carrie Fisher" role="Carol Peterson" thumb="http://image.tmdb.org/t/p/original/rfJtncHewKVnHjqpIZvjn24ESeC.jpg"/>
<Role id="4681" filter="actor=4681" tag="Rick Ducommun" role="Art Weingartner" thumb="http://image.tmdb.org/t/p/original/reHrybVr1GjF4pGXhtN9EUxS0zD.jpg"/>
<Role id="59586" filter="actor=59586" tag="Corey Feldman" role="Ricky Butler" thumb="http://image.tmdb.org/t/p/original/odE8az9kgHCkWMtWzfmcDBuZiww.jpg"/>
<Role id="104922" filter="actor=104922" tag="Wendy Schaal" role="Bonnie Rumsfield" thumb="http://image.tmdb.org/t/p/original/6rDQCbwOYXblJWeUL0stc5w1Sdz.jpg"/>
<Role id="90835" filter="actor=90835" tag="Henry Gibson" role="Dr. Werner Klopek" thumb="http://image.tmdb.org/t/p/original/5dmU4muna3kpU2aFM4eU2Ij12Xn.jpg"/>
<Role id="109963" filter="actor=109963" tag="Brother Theodore" role="Uncle Reuben Klopek" thumb="http://image.tmdb.org/t/p/original/2OLcOFM5vzJuINo8zDKWiFCRkgH.jpg"/>
<Role id="42691" filter="actor=42691" tag="Courtney Gains" role="Hans Klopek" thumb="http://image.tmdb.org/t/p/original/7u8dTzgr4ODfpKwdYoUlTwptoCq.jpg"/>
<Role id="109965" filter="actor=109965" tag="Gale Gordon" role="Walter Seznick" thumb="http://image.tmdb.org/t/p/original/thuO7MVoxDsoYNpMWmfrR1fWGtd.jpg"/>
<Role id="34243" filter="actor=34243" tag="Dick Miller" role="Vic, Garbageman #1" thumb="http://image.tmdb.org/t/p/original/c2lakgh0bCckVoDxDplqTvMLVZ4.jpg"/>
<Role id="35095" filter="actor=35095" tag="Robert Picardo" role="Joe, Garbageman #2" thumb="http://image.tmdb.org/t/p/original/5L0WCl3TzjeWdP8TqXfQ1n9uaOn.jpg"/>
<Role id="46563" filter="actor=46563" tag="Cory Danziger" role="Dave Peterson" thumb="http://image.tmdb.org/t/p/original/anrgnTltTHdNJ88uAqH1z85HkvA.jpg"/>
<Role id="54994" filter="actor=54994" tag="Franklyn Ajaye" role="Detective #1" thumb="http://image.tmdb.org/t/p/original/9TWfwYV72JlBAwkVk91k1lrTGGg.jpg"/>
<Role id="7823" filter="actor=7823" tag="Rance Howard" role="Detective #2" thumb="http://image.tmdb.org/t/p/original/i7tkpb7GLJXjwUNyrpOy63FiStt.jpg"/>
<Role id="109967" filter="actor=109967" tag="Heather Haase" role="Ricky's Girlfriend"/>
<Role id="29612" filter="actor=29612" tag="Nicky Katt" role="Steve Kuntz" thumb="http://image.tmdb.org/t/p/original/dbAeUQXzyf2HDFYtifWkHfE3SNW.jpg"/>
<Role id="109961" filter="actor=109961" tag="Billy Stevenson" role="Ricky's Friend"/>
<Role id="109966" filter="actor=109966" tag="Gary Hays" role="Ricky's Friend"/>
<Role id="24658" filter="actor=24658" tag="Kevin Gage" role="Cop" thumb="http://image.tmdb.org/t/p/original/egIApa0PPsHkAwrGnOAUtdqO6CQ.jpg"/>
<Role id="109964" filter="actor=109964" tag="Dana Olsen" role="Cop"/>
<Role id="109962" filter="actor=109962" tag="Brenda Benner" role="Walter's Daughter"/>
<Role id="78756" filter="actor=78756" tag="Patrika Darbo" role="Suzanne Weingartner" thumb="https://thetvdb.com/banners/actors/417021.jpg"/>
<Role id="28347" filter="actor=28347" tag="Sonny Carl Davis" role="Voiceover Actor" thumb="http://image.tmdb.org/t/p/original/bdpZH2zUh9WSRfxViA3oyvizNl0.jpg"/>
<Role id="79707" filter="actor=79707" tag="Kevin McCarthy" role="Ray's Boss (workprint version)" thumb="http://image.tmdb.org/t/p/original/kNEsGIBVMsKXB8qN6W2pFt4Wh8S.jpg"/>
<Similar id="27421" filter="similar=27421" tag="The Money Pit"/>
<Similar id="30745" filter="similar=30745" tag="Dragnet"/>
<Similar id="27413" filter="similar=27413" tag="Joe Versus the Volcano"/>
<Similar id="27410" filter="similar=27410" tag="Bachelor Party"/>
<Similar id="37997" filter="similar=37997" tag="Fletch"/>
<Similar id="38001" filter="similar=38001" tag="The Great Outdoors"/>
<Similar id="9521" filter="similar=9521" tag="Bill & Ted's Bogus Journey"/>
<Similar id="27424" filter="similar=27424" tag="Turner & Hooch"/>
<Similar id="13494" filter="similar=13494" tag="Scrooged"/>
<Similar id="49896" filter="similar=49896" tag="Uncle Buck"/>
<Similar id="26914" filter="similar=26914" tag="Roxanne"/>
<Similar id="54533" filter="similar=54533" tag="Fletch Lives"/>
<Similar id="26210" filter="similar=26210" tag="National Lampoon's European Vacation"/>
<Similar id="27418" filter="similar=27418" tag="Splash"/>
<Similar id="32781" filter="similar=32781" tag="Spies Like Us"/>
<Similar id="9526" filter="similar=9526" tag="National Lampoon's Vacation"/>
<Similar id="11505" filter="similar=11505" tag="The Jerk"/>
<Similar id="49841" filter="similar=49841" tag="Encino Man"/>
<Similar id="18409" filter="similar=18409" tag="House"/>
<Similar id="39830" filter="similar=39830" tag="Who's Harry Crumb?"/>
<Field locked="1" name="thumb"/>
<Extras size="1">
<Video ratingKey="22101" key="/library/metadata/22101" guid="iva://api.internetvideoarchive.com/2.0/DataService/VideoAssets(1119)?lang=en&bitrates=80,212,450,750,1500,2500,5000,8000&duration=88&adaptive=1&dts=0" type="clip"title="The Burbs" titleSort="Burbs" summary="" index="1" year="2016" thumb="/library/metadata/22101/thumb/1538252669" subtype="trailer" duration="88000" originallyAvailableAt="2016-12-27" addedAt="1538252669"extraType="1">
<Media videoResolution="1080" id="51682" duration="88000" bitrate="2500" width="1920" height="1080" aspectRatio="1.78" audioCodec="aac" videoCodec="h264" container="mp4" premium="1">
<Part id="51682" duration="88000" container="mp4" key="/services/iva/assets/1119/video.mp4?bitrate=2500" optimizedForStreaming="1">
<Stream id="129142" streamType="1" codec="h264" index="0" bitrate="2500" height="1080" width="1920" displayTitle="1080p (H.264)"/>
<Stream id="129143" streamType="2" selected="1" codec="aac" index="1" channels="2" language="English" languageCode="eng" displayTitle="English (AAC Stereo)"/>
</Part>
</Media>
<Media videoResolution="720" id="51683" duration="88000" bitrate="1500" width="1280" height="720" aspectRatio="1.78" audioCodec="aac" videoCodec="h264" container="mp4" premium="1">
<Part id="51683" duration="88000" container="mp4" key="/services/iva/assets/1119/video.mp4?bitrate=1500" optimizedForStreaming="1">
<Stream id="129144" streamType="1" codec="h264" index="0" bitrate="1500" height="720" width="1280" displayTitle="720p (H.264)"/>
<Stream id="129145" streamType="2" selected="1" codec="aac" index="1" channels="2" language="English" languageCode="eng" displayTitle="English (AAC Stereo)"/>
</Part>
</Media>
<Media videoResolution="480" id="51684" duration="88000" bitrate="450" width="640" height="480" aspectRatio="1.33" audioCodec="aac" videoCodec="h264" container="mp4" premium="1">
<Part id="51684" duration="88000" container="mp4" key="/services/iva/assets/1119/video.mp4?bitrate=450" optimizedForStreaming="1">
<Stream id="129146" streamType="1" codec="h264" index="0" bitrate="450" height="480" width="640" displayTitle="480p (H.264)"/>
<Stream id="129147" streamType="2" selected="1" codec="aac" index="1" channels="2" language="English" languageCode="eng" displayTitle="English (AAC Stereo)"/>
</Part>
</Media>
</Video>
</Extras>
</Video>
</MediaContainer>
The nvidia moderator states that Plex devs are aware of the issues (see thread below) and that they are not related to their firmware and the problem lies with Plex. Maybe @sixones could provide an update to if they have found where the issue lies.
https://forums.geforce.com/default/topic/1095068/shield-tv/shield-experience-7-2-3-test-images/21/
Every single file of a moderate bitrate i.e. above 20Mb.
I am not personally aware of the discussion between Nvidia and Plex so I don’t know what is known or not. However, that response in that thread sounded to me like an issue we were having related to where PMS is storing the appdata. I know there are issues around that. I’m not aware of anything specific related to this high bitrate issue. As I said, I was able to play a 40 and 100 Mbps stream fine.
The difference I see is that you are using DTS-HD-MA audio. I know we don’t support that, so it could be something with PMS trying to transcode the audio, or if you have passthrough enabled, it can only pass the DTS core, so maybe something going on there.
Can you recreate and send me your PMS and Shield logs?
I get that you’re trying to help but every time I see you post something there’s always at least one error in it.
“The difference I see is that you are using DTS-HD-MA audio. I know we don’t support that, so it could be something with PMS trying to transcode the audio, or if you have passthrough enabled, it can only pass the DTS core, so maybe something going on there.”
This is factually incorrect. SHIELD TV has always supported DTS-HD MA (ignoroing pre 1.5 ExoPlayer beta days) and PMS has always been able to send it. SHIELD TV even supports weirder esoteric formats like DTS-HD HRA. I’ve had passthrough on since day 1.
Luckily my problem seems to have been resolved with the update to the beta PMS which is strange as heck but I’m not complaining! :smiley:
Ah darn it. I’m thinking of optical. Yeah, dts-hd-ma and others are supported via hdmi.
Yay. Not sure what changed. There’s nothing around how audio is handled. I wonder if you had a bad previous update.
I can’t be a Shield firmware problem, since the same Shield can play literally anything with Kodi or other software. The Plex issue is also “solved” by simply uninstalling all Plex client updates (so you’re operating on the oldest version) and it plays fine. It’s a Plex client app issue.
