Every few days I’ll have to restart PMS after finding it has consumed nearly all the system memory. Currently the “Plex Media Server” process is using 95% of system ram (19.5 GB.)
The web dashboard incorrectly reports that it’s only using <5% of system ram.
This has the effect of making some clients very unresponsive. The web library will sometimes fail to load. The iOS app will actually crash around 30 seconds after opening.
Nothing in the logs jump out to me, but I’m not sure where to start looking.
Relevent section of ‘top’ if helpful:
Tasks: 34 total, 1 running, 33 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.1 us, 0.0 sy, 0.0 ni, 99.9 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem : 20480000 total, 483020 free, 19955044 used, 41936 buff/cache
KiB Swap: 8388604 total, 8138860 free, 249744 used. 524956 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
3096 plex 20 0 23.018g 0.018t 27644 S 0.5 95.3 338:27.74 Plex Media Serv
3086 plex 20 0 4628 232 232 S 0.0 0.0 0:00.00 sh
3122 plex 35 15 1788472 77168 7184 S 0.0 0.4 1:10.78 Plex Script Hos
3174 plex 20 0 438028 5460 5368 S 0.0 0.0 0:01.85 Plex Tuner Serv
3208 plex 20 0 953068 12560 4820 S 0.0 0.1 0:21.54 Plex Script Hos
3210 plex 20 0 956192 12176 4864 S 0.0 0.1 0:20.51 Plex Script Hos
3212 plex 20 0 1600296 196812 7800 S 0.0 1.0 6:12.53 Plex Script Hos
5267 plex 20 0 17932 2972 2188 S 0.0 0.0 4:56.27 EasyAudioEncode
These logs unfortunately cover a small window due to playback activity.
Starting:
Jan 18, 2020 14:39:35.478 [0x7f2933d3c700] INFO - Plex Media Server v1.18.4.2171-ac2afe5f8 - Ubuntu PC x86_64 - build: linux-x86_64 debian - GMT 00:00
Jan 18, 2020 14:39:35.478 [0x7f2933d3c700] INFO - Linux version: 18.04.3 LTS (Bionic Beaver), language: C
Jan 18, 2020 14:39:35.478 [0x7f2933d3c700] INFO - Processor Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
Jan 18, 2020 14:39:35.478 [0x7f2933d3c700] INFO - /usr/lib/plexmediaserver/Plex Media Server
Jan 18, 2020 14:39:35.477 [0x7f28357fa700] DEBUG - Audio Stream: 229195, Subtitle Stream: -1
Ending;
Jan 18, 2020 15:18:44.780 [0x7f284e7fc700] DEBUG - Request: [192.168.2.29:56560 (Allowed Network (Subnet))] GET /statistics/resources?timespan=6 (22 live) TLS GZIP Signed-in Token (tomkiley)
Jan 18, 2020 15:18:44.782 [0x7f292a60b700] DEBUG - Completed: [192.168.2.29:56560] 200 GET /statistics/resources?timespan=6 (22 live) TLS GZIP 1ms 968 bytes (pipelined: 11)
Jan 18, 2020 15:18:46.873 [0x7f292ae0c700] DEBUG - Auth: authenticated user 1 as tomkiley
Jan 18, 2020 15:18:46.873 [0x7f28b6ffd700] DEBUG - Request: [192.168.2.29:56535 (Allowed Network (Subnet))] GET /statistics/bandwidth?timespan=6 (22 live) TLS GZIP Signed-in Token (tomkiley)
Jan 18, 2020 15:18:46.883 [0x7f292ae0c700] DEBUG - Completed: [192.168.2.29:56535] 200 GET /statistics/bandwidth?timespan=6 (22 live) TLS GZIP 10ms 2749 bytes (pipelined: 151)
Tom,
I will provide a PM channel to you so I may see unedited logs if you’re willing.
What I saw looked like the LAN IP was 111.x.x.x. I have seen such things done in the past where folks think LAN IP can be anything they want because they are unaware of the RFC-1918 requirement and how basic IP routing works.
Might it be possible to see: a) a full set of logs inclusive of the agent and other logs b) all of which are unedited?
