Server Version#: 1.32.6.7557
Player Version#: Multiple
Tried playing a HEVC video with HLG on several Apple devices (Desktop app, Apple TV 4K, iOS). The result is severe video stuttering, but audio seems to work. It works if I disable Hardware Decoding but no HDR. Chrome and Safari on Mac wants to transcode and they can normally play HEVC.
Friend was able to play successfully with all his devices (Windows app, Nvidia Shield, Chromecast with Google TV and even Chrome on Windows). It also plays fine in IINA on MacOS, both with HDR and without.
Something with Plex and Hardware Decoding HLG on Apple devices? Is this known?
File:
Format : Matroska
Format version : Version 4
File size : 7.77 GiB
Duration : 59 min 5 s
Overall bit rate : 18.8 Mb/s
Frame rate : 25.000 FPS
Writing application : mkvmerge v79.0 (‘Funeral Pyres’) 64-bit
Writing library : libebml v1.4.4 + libmatroska v1.7.1
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 18.6 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.090
Stream size : 7.69 GiB (99%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : HLG
transfer_characteristics_Original : HLG / BT.2020 (10-bit)
Matrix coefficients : BT.2020 non-constant`
