Home page not showing latest watched
Just had to reboot the computer and reinstall plex, but for some reason, the server had reset. So i set it up again, but when watching it now, all my shows and movies don’t show up on the home page anymore. instead all that’s there is plex related shows, nothing from my server. so I have to navigate through the “more” tab and then see my stuff… just trying to see how i can fix this?
i tried to just make a new server but my old one just keeps popping up now.
thanks in advance
On Android TV click on your username on the top left and select Reset Customization to get a wizard to select the sources you want.
The home screen sidebar is essentially “favorites” and the More menu has everything.
You can individually pin/unpin your libraries or other sources you want to the home screen and unpin the other sources if you do not want them on home screen. When focused on a library or sources move to the left and there will be a menu you can select to pin them. In the home screen side bar you can also use this menu to reorder the libraries in the side bar
If you do not plan to use our media sources you can disable them at https://app.plex.tv/desktop/#!/settings/online-media-sources for your account so they do not show up in any Plex app you use.
Screenshot_11_1_23__7_48_PM
additionally the order off the rows displayed on the home screen from your server libraries. Continue Watching will always be there but rows like Recently Added is determined by the server library recommendation settings. https://support.plex.tv/articles/manage-recommendations/
