Home Screen Issue
I recently swapped my Plex server to a Dell OptiPlex T140 running Server 2019 after running it off of an older gaming laptop for the past 3 years. Everything is working great except for the home screen. If I log in via web, the home screen looks just fine. I’m also having the same issue if I use the app on my phone or iPad.
When it default opens to the home screen, it only shows the newly available content through Plex instead of my own library. I have to go the left sidebar, click more, then choose the server name. If I click to edit the customization of the home screen, I’m not seeing “recently added tv” or “recently added movies” to add them back. I have also tried to reset customization to default, to no avail. Any suggestions?
With left menu scroll down to more and Pin your Libraries. if libraries are not there you will need to add them again
I actually figured it out! The new server wasn’t listed as my preferred server on my account even though I had deleted the old server. I had to click my username in the sidebar, then click reset customization. That seems to have done the trick.
Cool, glad your up and going
