Home Screen
I Just opened my client on Roku, iPhone and Firestick and my Home Screen shows all the Categories I have on the Left… Before it worked great where you had New Movies, New TV Shows, you Music, etc and you can control the homscreen. Now its only reset to default and if you change it also removes/unpins you category on the left. BTW my Plex Server Version 1.19.1.2645.
You might want to update your Plex Media Server… version 1.19.1 was released more than a year ago.
As for the home screen:
Plex have announced some weeks ago that the manual customization of the home screen as it used to work will no longer be supported. Instead there’s a new option to manage those recommendations etc.
https://support.plex.tv/articles/manage-recommendations/
There have been requests to separate those hubs per library (instead per media type). Therefore the home screen recommendations/hubs are separated by default. However with the new options/configuration you can also enable the “Recently Added” hubs to be merged per media type (e.g. movies, shows, music…).
Ok which Plex Media Server version allows you to change the library Management?
From the support article linked above:
Managing Recommendations
Requirements:
  • Plex Media Server v1.22.1 or newer
  • Plex Web v4.53.0 or newer
