Horizontal color bars intermittent during playback
While watching a recently ripped blue-ray, I occasionally am getting about 1/2 seconds of four horizontal bars with static thin vertical lines in each bar, the four bars filling the screen. Each bar approx 1/4 the screen height, and each bar has a multitude of thin vertical lines in a panoply of colors. After a half-second or so, the normal video returns for about 20-30 seconds, then the color bars return, again for about 1/2 seconds. This is from a recent download and install of the latest plex media server. The blue-ray was ripped with makemkv. No mods to the default configuration. Thanks for looking.
I’m having a similar issue with a new Lord of the Rings Blu-ray I just bought. I’ve ripped over 100 blu-rays and have never had this issue. One difference with my issues is that it occurs less frequently than yours. This issue does not occur in VLC, but it does using Plex server and Xbox 1. Did you figure anything out?
Me too. I just ripped LOTR FOTR disks 1 and 2 also using makemkv with default settings, and both exibit random color bars as described.
Sorry to dig up an old thread. Having this same issue with Guardians of the Galaxy 2. Anyone find a solution to this?
