How backup audio metadata?
Server Version#: 1.40.2.8395
Player Version#: 4.125.1
Hi!
I manually put all the tags/labels and music labels in my audio files
Which file is responsible for all this?
To make a backup of it in case of reloading my library
Or should I make a full copy of the folder on the NAS ?
Are you actually writing meta tags into your audio files,
or are you just editing the albums etc. inside of Plex?
I urge you to do the first option as much as possible and only edit inside of Plex if you cannot achieve the result with embedded meta tags.
As for your original question: https://support.plex.tv/articles/201539237-backing-up-plex-media-server-data/
Main tags (album/cover/artists) I edit using software
Plus sees it and immediately displays it
But Plex tags (music labels, for example), he prescribes himself and I delete them with my hands
There are meta tags for record label as well.
At least in flac files, I see Plex using them.
What this software ?)
mp3tag
