How can I add a transmitter to Plex?
I presume there is a file I can edit - I need to add a UK transmitter as mine is not there, and it’s easier than using the national one and then having to pick and choose channels - especially as with my QuadHD I have to do it twice…
Actually scrap that - I found the ini files. Seems that my transmitter (Winter Hill) is there, but is missing some transponders (com7 and com8) - not sure exactly what I need to enter to add the missing ones. Anyone know?
Never mind, I gave up on Plex DVR - I’ll look for a different way to approach it.
to get all the channels you don’t select winter hill as some of the channels we get are on another tower (I’m in Manchester) need to scan all channels and manually select almost all the channels I use sky for the list but I’m still missing guide info for a few channels.
if you find a better solution let me know please wasted a few months on this now. the closest I found costs more as you have to use 2 programs one you pay for and pay yearly for a guide if you want more than 2 days of programming.
