How can i clean a plex folder?
Server Version#: 1.18.3.2156-349e9837e_amd64
Player Version#: old samsung TV app
host server: debian on LXC
Hi I’ve got a pretty big plex folder, about 2.4GB, how i can clean it?
Is there a specific tool can i use for?
this is the folder looks like:
sebastian@PLEX:~# du -h * /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/ | sort -rh
2.4G	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/
682M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache
627M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder
498M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support
492M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Metadata
328M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Media/localhost
280M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins
261M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Metadata/Movies
253M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data
240M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.plugins.trakttv
232M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Metadata/TV Shows
222M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.plugins.trakttv/Backups/trakt/1.bgr
197M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Trakttv.bundle
196M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Trakttv.bundle/Contents
195M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Trakttv.bundle/Contents/Libraries
175M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.plugins.trakttv/Backups/trakt/1.bgr/2019
151M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Databases
116M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.plugins.trakttv/Backups/trakt/1.bgr/2019/12
109M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Trakttv.bundle/Contents/Libraries/Linux
95M	/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Caches
thx
2.4GB is tiny, compared to servers with larger media collections.
See https://support.plex.tv/articles/202529153-why-is-my-plex-media-server-directory-so-large/
Do remove the data of old, now useless plugins.
I already did it, then there are no problems; I will try to follow the suggestions on the page you linked. thx
