Hi
I have many albums that plex hasnt picked up the artwork for. The artwork is embedded into the files. How can I get plex to fix these matches for many items at once rather than doing each one individually?
You could Refresh Metadata on the whole Music library, or you could select only the albums you want using the multiple selection feature in album view mousing over a poster and clicking in the upper left circle to select.
While I’ve embedded a lot of cover art into my files, sometimes it’s just as easy to drop the photo into the same folder correctly named.
As the album cover art, the name must be one of:
I use all lower case on every filename to avoid case issues.
My directories use normal capitalization.
And the choice you make for your Album Art source will affect your results.
