I recently purchased a Synology NAS DS216+II. Upon setup of the NAS on 14 Dec 17 - I loaded Plex and was able to utilise all functionality via my NAS.
However, an update to DSM 6.1.4-15217 Update 5 resulted in Plex being stopped and the short-cut being removed from my Control Panel.
I have read several threads of how to re-establish the link with Plex but none of the methods suggested are working. I keep getting the same error ‘Failure to run Package Service’.
On my last attempt - I shutdown my NAS, router/modem and restarted; thereafter, I uninstalled the Plex software from my NAS, confirmed that ‘Trust Level’ settings were correct before adding in the correct Plex certificate and downloading the lastest version of Plex from the website i.e. Intel 64 - DSM +6.0. Encountered a failure to run.
I have also tried to install Plex (i.e. version 1.10.1.4602.f54242b6b) using the link from the synology NAS interface with no success.
Can anyone assist with this challenge; I cannot understand why Plex does not work anymore?
Thank you for the quick response. The error message is attached in this message. I am unable to run the installed version of Plex - it ‘starts’ and then ‘stops’.
I uninstalled PMS, rebooted and reinstalled the PMS. Unfortunately, this did not solve the problem - I attached a screenshot of the view from Package Centre (refer: Attachment).
Okay, I would like to follow your suggested shell-level method, but am a complete novice with the NAS. I was able to complete Step 1 and 2 i.e. Enable SSH. Beyond that point I am lost…
Am i supposed to log-off as DNaidoo77 and re-log on as Admin. I am the only user with administrator permissions.
I have highlighted the commands for you to use in purple. You can copy & paste them into the shell terminal session exactly as I typed them.
As you go through the steps, perform the action.
When you encounter my highlighted text, copy & paste that text in the window and press Enter to have the NAS execute the command
At the end of Step 7, there should be some errors regarding PMS for us to see. If there aren’t too many, please copy & paste them here. If there are a lot, it may be better to copy/paste into a text document which you can attach with your next post
I performed a complete cold start of PMS. Plex seems to have recognised/located my server :). Thank you for this step in the correct direction. However, it does not find my movies.
I have the all movies files nested in folders located in a Folder called ‘Movies’. I am uncertain whether I need to apply specific permissions to ensure Plex can locate these movie files.
On Synology you must make certain that user plex has permission to access your top-level shares. Without that permission, it will not be able to see them (Linux is very strict on security and plex is not a privileged user in the Synology environment).
Here is the screen shot of what you the minimum permissions you should see for PMS on Synology.
Regarding structure, PMS prefers:
Top level share (Movies)/
Movie (year)/
Movie (year).ext
MovieExtra-type.ext (if you have any)
Thank you for your assistance with my problem. Plex is working on my NAS again. I have successfully established a Movie and Music Library. Hopefully, this will not be impacted again. I appreciate you patience in addressing my queries…
I recommend manually Optimizing the Database after you create each section. This is because NAS processors are slower than desktops. The database is becomes harder to navigate when large amounts of media are added (like music). Optimizing it puts the database in pristine ordering and greatly speeds up operation.
