How can I repin a folder on my dashboard that I unpinned by mistake. When I go to my tv the folders is no longer visible.
Charlie
Check out the More button in the app’s sidebar. There you’ll find all libraries and can pick the ones to pin.
Hello
I opened more and all my folders are pinned but when I go down to my tv the folder I unpinned is not there. Is there something I have to do at the tv?
Thanks for your help
Charlie
The customizations are per-device. If you want to change the pinned/unpinned libraries in the tv‘s sidebar(or reorder them), you need to do that on the TV itself.
Worked Thank you
