I have two HDHomerun tuners. One gets a better signal than the other.
No mater the order I define them to Plex, it always puts the HDHomerun Connect above the HDHomerun Connect QUATRO.
When recording one show only, Plex always pics the channel from the first tuner in the list.
I would like to change the tuner device list order in Plex such that the HDHomerun Connect QUATRO is first so it will always get used first.
there is currently no way to do choose which device or tuner plex will use.
If you want specific recordings to come from a particular device, the only work around is to set some channels to one device, and other channels to the other.
