i donn’t have public IP,so i use a server with FRP , that i can connect my plex server through my own domain
but the Remote Access in the setting still not work,like:
frp is a tool for someone don’t have public ip,to use it you have to buy a server with public ip , and set a connection between your own home and server,then forward all the data from sever to your home , just like you have a public ip
yeah…but,it seems doesn’t work,i set my server listen at port ‘32400’,then added my domain name at settings-network-‘Custom server access URLs’
but when i use my phone watch the movie,it still reminds limited netwok
It must be an URL, complete with protocol and port, not just a domain name.
You will need to use http and not https, unless you also have a publicly trusted certificate for this domain name.
‘Secure Connections’ need to be disabled, or it will continue to use the secure connection which is only available with the relay connection.
