How do I access the Plex plugin folder on 4 GB WD Mirror? I am using a Macbook Pro computer.
You need to download WD cloud Mirror app or go to the local ip of your WD
cloud server and make sure under shares you create a line plex_config and then with the app WD my cloud you should see folder plex config/plex media Server/plug in
