I use the live DVR with a plex pass to record OTA TV shows. Currently the recordings go to a directory on my C: Drive and I want to change them to go to a different drive but I can’t figure out where the setting is that controls the DVR recording location. Any insight would be appreciated. Thanks in advance.
Server Version#:
Tuner Make/Model: HD Homerun
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Under manage libraries, add a new library and point it at a folder where you want the recordings to go.
Then when you set a programme to record in the dropdown select that library.
Thanks!
You will also need to change the location on each already scheduled program.
