Is it possible to redirect the storage of the Plex DVR to an alternate location? I have an internal HD that I would like to use solely for LiveTV/DVR purposes.
Just setup a new Library of Type TV and you can use that when you schedule recordings.
Or add another path to an existing library (TV or movies), and choose the path you want to record to when you set up the recording.
- “Add folders” in https://support.plex.tv/articles/200289266-editing-libraries/
- When you set up a recording, as in https://support.plex.tv/articles/226074728-setting-up-recordings/, there will be an additional dropdown to choose which of the library’s different paths to store the recording in.
