How do I customize home screen to add cartoon category???
So currently the home screen has a “TV” category and a “movie” category how can I add a third category for just cartoons. It seems I only can separate into above two for displaying on home screen or I can to separate out those files via folders etc… but I want it to display newly added on main page.
There is no cartoon library type. there is Movies, TV, other videos, music and photos.
if you have multplle Tv libraries they will all be in that same row. You can’t make other types of rows
I’m not sure what type of library your Cartoon library actually is but if you turn on “Include in Dashboard” for that library recently added items will show in the RA for that type ( i’m guessing you probably have it in aTV type library)
Ok thanks…
Other videos is their a way to separate them to display under that or what is considered other videos?
if “Include in Dashboard” for that library is enabled for a “other videos” type library you will see a “recently added videos” row (if enabling for first time you may have to leave home screen and go back)
