How do I disable podcast recommendations?
I’ve started using the podcasts feature more seriously, but I’m finding the recommendations column which appears on every dash view to be seriously annoying. How do I turn it off? Can’t seem to find it in any of the settings, seems to just be attached to whether podcasts as a whole are on or off. But I only listen to 3 podcasts, and so having this massive extra column full of crap I don’t care about is really annoying, and definitely is a big detractor.
Suggestions appreciated!
