How do I enable TrackOffsets to allow for variable speed playback?
Server Version#:4.55.0
Player Version#:7.15
In the most recent iOS App update it removed the ability for me to adjust the playback speed for my Audiobooks. The update to 7.15 says “Only show playback speed for podcasts and for libraries with enableTrackOffsets”, but I have no idea where to find the enableTrackOffsets option.
Please help!
It’s Store track progress, in the advanced settings of your music (audiobooks) library:
If you enable it and then restart the Plex app on iOS, you should have the ability to modify playback speed.
That did it. Thank you so much!!
No problem, glad it worked!
