I would like to specify a folder containing my movies. The Setup Wizard must have helped me initially, but now I want to change the location and I"ve spent a whole lot of time looking for the secret handshake…
Before you do this, if you are moving your movie files to another location, you should look at this page for the best way to do it. It will save you some steps.
When you get to the ‘Edit Libraries’ part of the process, here’s how you do that:
In Plex Web, edit your Movies library:
Go to the ‘Add Folders’ tab:
EXACTLY what I was looking for! Thanks for the help!
