How do I fix a TV Series Mismatch?
Version 4.41.1
I’m unable to find any settings for a TV Show that is mismatch. It’s very easy for Movies, but nothing for TV Series?
Any suggestions?
When viewing the TV show page in Plex Web, click on the three dots. You should see choices for Fix Match / Unmatch listed.
Also available when viewing the TV Show library. Mouse over the picture for the show. Click the three dots in lower right corner. You should see Fix Match / Unmatch.
Screenshot (178)
Make sure you are looking at the show level, not the season or episode.
Edit - If you are just trying to fix individual episodes, you do that by renaming the file and doing a new library scan.
I feel like an idiot that I didn’t see this earlier. Thank you for pointing me in the right direction.
Cheers
