How do I get metadata from prior recordings to show up in Plex?
Hi all,
I have a number of different recordings of Frontline from either previous installations of Plex or Tivo, etc. The recordings that this instance of Plex have their metadata - the prior ones do not. There doesn’t appear to be any difference in the naming of the files between prior recordings and current ones. Refresh meta data doesn’t seems to do anything either.
Any suggestions?
Thanks! Will.
