Plex (running on Synology DS923+, DSM7+´) has fetched alot of trailers etc for my movies and I can’t get rid of them. I’ve disabled the option “Find trailers and extras automatically (Plex Pass required)”, it was previously enabled. I disabled it a few days ago but all stuff is still there.?
Thanks.
After disabling extras, ensure you refresh all metadata for the library.
I’ve tried that for specific movies but with no success. I’ll try on the entire library.
Tried it, nope, trailers and behind the scenes still there…
EDIT: Ah now I get it, all libraries had an “find extramaterial” had a checkbox in it’s settings. This was not mentioned in the documentation that I’ve seen. Issue solved anyway.
