Extras and Trailers showing up but I have disabled "Find trailers and extras automatically"
I never watch ‘extras’ such as trailers and ‘Behind the Scenes’, and I don’t want it to use disk space to store them, nor bandwidth to download them. Thus I have the option disabled to download these items:
However, they are showing up anyway on the movies:
  1. How do I disable this for good?
  2. How do I delete the downloaded extras to reclaim the disk space?
Any thoughts/comments @ChuckPA or @sa2000 ?
where did you uncheck this option?
changing the settings in Settings > Server > Agents > Movies > ... won’t automatically apply this to the libraries you have already configured.
please check if the option is also unchecked in that library’s advanced settings:
Neither location has the option enabled, but the original picture was from the ‘Edit Library’ screen.
At some point, most likely by accident, it was enabled. That’s what would cause the thumbnail to come down and be included with the movie’s metadata. The extra itself isn’t stored locally.
Take one of your movies with that and, with the Extras option now off, Plex Dance it making certain to perform the Scan-Empty-Clean in order before moving the movie back into position.
These extras are not downloaded to your server.
It is merely the small thumbnail picture what is stored on your server.
If one of your clients decides to watch such a video, it is streamed directly from the internet to this client.
I had come across this topic and was following it: https://forums.plex.tv/discussion/comment/1498573#Comment_1498573
However, I found this wasn’t sufficient and that I needed to also do a ‘Refresh Metadata’ for it to be removed.
Before I did the above, I had to address it thinking the option was selected. I disagree that it was ever selected, because I just re-setup Plex and I know for certain I didn’t use that option. However, I was using my backup/restore Perl script, which worked great incidentally (https://forums.plex.tv/discussion/301248/backing-up-the-plex-db-and-preferences-new-perl-script-for-ubuntu#latest). However, it looks like while it restored everything, Plex somehow thought this was enabled and was acting as if it was enabled, even if it appeared not-enabled.
I went in a cycled it, enabled/apply/un-enable/apply before I did the above. And that seems to have did the trick.
That is actually a lot better than I was imagining. I might have just left it there if I had understood it wasn’t consuming but a thumbnail’s worth bandwidth and storage. Thanks for explaining the details.
