My Plex plugin is installed on a ssd on my freenas. I dont know how to select it as my Transcoder temporary directory.
Should I write /mnt/ssd/cache or /ssd/cache ?
Thank you!
Thank you!
Check where your drive is mounted. As far as I know your path is /mnt/[Volume_Name_of_your_SSD]/[Folder] , the Volume name usually is the name displayed in the Windows or Linux File Manager.
