How do I turn off the background color of subtitles?
How do I turn off the background color? Does anyone know? Visually, it feels bad. But the user cannot choose to turn it on or off.
The audience used to pay attention to the picture, and then pay attention to the text again. Now, the black area of the caption catches my attention. It won.
Without the switch, I had no choice.
Ask for help!
(This is for external subs - burned in subs are not formattable)
You cannot make changes to .SRT files since they are simple text files. The “ASS” (not joking) is supported by PLEX and has some configuration settings. Subtitle Workshop can convert and format sub-titles. Subtitle Workshop 6.3.4 Download Free - VideoHelp
You’ll have to save them in a supported format and not SRT
Supported Subtitle Formats
The following formats are fully supported either as embedded tracks or external subtitle files. Full support means they are compatible with all Plex Apps, including clients that require transcoded media.
  • SRT ( .srt )
  • SMI ( .smi )
  • SSA (or ASS) ( .ssa or .ass )
  • WebVTT ( .vtt )
Other formats such as VOBSUB, PGS, etc. may work on some Plex apps but not all. For the majority of apps, both VOBSUB and PGS subtitles will require the video to be transcoded to “burn in” the subtitles for streaming.
Thank you for your reply. I don’t think the subtitle format caused the trouble. I did the test, using ass format, subtitle background is also black.
You have to edit the file once it is in ASS format. I’m not an expert here but the links in the subtitle Workshop explain the re-coding. Kind of technical but it is free. Simpler editors can be free and upgraded to paid to get more options like https://www.kapwing.com/
There does not appear to be an easy path
Roku, right?
