How do you erase library when Happy Dance doesnt work anymore
Ok, that was is the missing piece of info. You don’t have 1 movie library, you have 15. I do the same thing, so I get why you do it this way. It just wasn’t clear from your description before. Deleting and recreating these would be tedious. What I mentioned about needing 1 file, is for the library.
So if “Movies - Biography” points to “Movies\Biography” you need 1 file in that “Biography” folder. So you will need 15 files, 1 in each of these folders. Same goes for TV shows if you need to change those too.
Those should work, it does for me. I have them named that exact same way. Although I do have them in separate folders. Are these mkv or mp4 files? If mp4, check the metadata in the file and see if the titles are the same. That can cause PMS to combine them.
