Is there a github issue tracker, or similar that I should use for reporting issues, requesting features, or is the forum the only place where that is done?
Here is the only place.
Just because you don’t see a response doesn’t mean it wasn’t reviewed.
Ok, thanks. I’m used to an issue tracker where you can see progress, and prioritization.
