Greetings
How is “analyzed the media but intro could not be found” marked in the .db?
If an intro is found media_parts.extra_data has something like intros= in it but where is the marker for “nothing found”
Greetings
There is no such thing. It looks the same as if the show has never been scanned.
How does the plex server know not to search for intros again on the same files during the schedulded task window?
AFAIK it stores something in the DB, but that doesn’t translate into the XML.
Here is a query which returns the IDs of the seasons which haven’t been scanned for some reason.
select distinct(metadata_items.parent_id) from metadata_items join media_items on metadata_items.id=media_items.metadata_item_id join media_parts on media_items.id=media_parts.media_item_id where metadata_items.metadata_type=4 and media_parts.extra_data not like '%pv^%3Aintros=%' escape '^' and metadata_items.id not in ( select distinct(metadata_items.id) from metadata_items join media_items on metadata_items.id=media_items.metadata_item_id join media_parts on media_items.id=media_parts.media_item_id where media_parts.extra_data like '%pv^%3Aintros=%' escape '^' ) order by metadata_items.added_at
Thanks, appreciated. I will try that ![]()
I am not looking at the XML but in the db, currently i am using this query to check for missing Intros:
SELECT file FROM media_parts INNER JOIN media_items ON media_parts.media_item_id = media_items.id INNER JOIN metadata_items ON media_items.metadata_item_id=metadata_items.id WHERE metadata_items.metadata_type IN (1,4) AND media_parts.file NOT LIKE '' AND media_parts.extra_data NOT LIKE '%intros%' AND file LIKE '%erie%';
(yes i know)
But this shows already scanned files with no intros found as well, so i am looking for the
So I can script around that.
That’s about all I can gather, sorry!
Tried it, works for me so far, thank you!
