How to add a 16 x 4 lcd screen
help… I’m trying to install a small 16x4 screen to use as a display (and some buttons to control it).
I’ve started following this tutorial… https://github.com/RasPlex/RasPlex/wiki/GPIO-LCD but when i try to copy the config file from /etc/LCDd.conf it doesn’t exist …
Are there any updated instructions anywhere? or can someone post a config file I can start from?
ok… i’ve found a copy of the correct driver and a config file. I’ve also enabled it within plex, but its still not running… I’ve tried to find the daemon on the build but it doesn’t seem to be there! apt and yum don’t work on LibreElec… so where now!
this may help
22:05:13 T:1733293024 WARNING: Read - waited for data but got none
22:05:14 T:1963775888 ERROR: Unable to load LCD skin file special://masterprofile/LCD.xml
22:05:14 T:1963775888 ERROR: XLCDproc::Connect - Unable to resolve LCDd host.
22:05:14 T:1963775888 ERROR: XLCDproc::Initialize - Connect failed. Retry in 4 seconds.
22:05:18 T:1597342688 NOTICE: ## LibreELEC Addon ## 0.8.9
22:05:19 T:1963775888 ERROR: Unable to load LCD skin file special://masterprofile/LCD.xml
22:05:19 T:1963775888 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
22:05:19 T:1963775888 ERROR: XLCDproc::Initialize - Connect failed. Retry in 8 seconds.
22:05:27 T:1963775888 ERROR: Unable to load LCD skin file special://masterprofile/LCD.xml
22:05:27 T:1963775888 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
22:05:27 T:1963775888 ERROR: XLCDproc::Initialize - Connect failed. Retry in 16 seconds.
there is a lcd.xml file in the /storage/lcdproc directory!
ok… worked it out… LCDd isn’t on the build… you have to add it and configure it… luckily they have only half removed it, as the hook into OpenPHT is still there…
Hallo bpgoa,
i have the same Problem. Can you help me please an give me instructions how i did it?
thx
