RasPlex 1.8.0 LCD Display 16x2 LCDProc
Hello,
No connection to LCDProc!
00:20:12 T:1750070240 NOTICE: ## LibreELEC Addon ## 0.8.9
00:20:12 T:1963497824 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
00:20:12 T:1963497824 ERROR: XLCDproc::Initialize - Connect failed. Retry in 8 seconds.
00:20:12 T:1800401888 WARNING: Read - waited for data but got none
00:20:20 T:1963497824 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
00:20:20 T:1963497824 ERROR: XLCDproc::Initialize - Connect failed. Retry in 16 seconds.
00:20:36 T:1963497824 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
00:20:36 T:1963497824 ERROR: XLCDproc::Initialize - Connect failed. Retry in 32 seconds.
00:21:08 T:1963497824 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
00:21:08 T:1963497824 ERROR: XLCDproc::Initialize - Connect failed. Retry in 64 seconds.
00:22:12 T:1963497824 ERROR: XLCDproc::Connect - Unable to connect to host, LCDd not running?
00:22:12 T:1963497824 ERROR: XLCDproc::Initialize - Connect failed. Giving up.
My LCDd.confLCDd.7z (3,5 KB)
Need Help!
Thx
Hi people, it seems that lcdproc is not installed. How can I install it?
English
I’m already on. So the LCDProc run. It starts the /etc/LCDd.conf. In this conf wrong drivers are registered. That’s why it does not work! / etc is unfortunately schrebigeschütz. That’s why I can not edit any files there. Can somehow edit the / etc?
Is there at least in the forum a Linux professional, who can help me with this problem?
Deutsch
Ich bin schon weiter. Also der LCDProc läuf. Es startet die /etc/LCDd.conf. In dieser conf sind falsche treiber eingetragen. Deshalb funktioniert das ganze nicht! /etc ist leider schrebigeschütz. Deshalb kann ich da keine Dateien bearbeiten. Kann man irgendwie die /etc bearbeiten?
Gibt es hier einen Linux Profi, der mir bei diesem Problem helfen kann?
