Server Version#: 1.25.2.5319
Player Version#: 5.29.1
Hi everyone,
How do I adjust the hours on Plex Server? Is there any option for this or file that I can edit to fix?
My server is clocked one hour early.
Thank You!
Hi everyone,
Thank You!
Plex is using the time of the underlying OS.
So you’ll need to make sure the OS is set to the correct timezone (with/without DST).
