Server Version#: 1.21.1.3830
Player Version#: Plex-1.26.0.1531-92029e9e-x86_64.zip
where the adjust interface in the macOS app?
According to the article linked above, Plex for Mac is not supporting this feature (yet?).
Supported Plex apps:
- Amazon Fire TV
- Android (mobile)
- Android TV
- Apple TV app
- iOS
- Smart TVs (LG 4K/UHD [webOS 2.0+], Samsung 2016+ UHD)
- Xbox One
Although it is not listed, Subtitle Offset is supported in Plex Web, https://app.plex.tv/desktop (just tested w/ Chrome on Win10).
That might be an option until the feature is supported on Plex for Mac/Win.
For me, Plex Web is not a solution cause my server has poor performance,I have to disable stream transcoding, but Plex Web seems must enable stream transcoding.
Any plan to support this feature? Many sutitles are not match so must adjust the offset, in China, sutitle is a heavy use feature.
