How to Close Mini Player from within Plexamp
Started moving my music library to plex so its my first time using the plexamp app. One annoyance I’ve seen is that it seems impossible to close the mini player within the app.
To reproduce, start to play something in plexamp. Then, stop the play. You can then minimise the player window but it never closes. Swipe right and left does nothing. See screenshot at below …
If I do the same thing with the full plex android client I have an X on the mini player to close it. See below …
One problem with being unable to close this mini player within plexamp is that it causes the plex server and its dashboard to keep this stopped track (which it considers as paused) on its dashboard. It will eventually be removed but takes 5ish minutes, guess its hitting a timeout.
Is there a way to close this or have the developers designed it this way ?
Stopping playback (instead of pausing) is almost never necessary in Plexamp. That’s why it isn’t that obvious how to do it.
Long press/tap on Pause/Play.
Look at [How To] Plexamp 3.0 - Settings and the linked post within.
Thanks, that was it exactly :plexheart:
