Add an X to close player
It would be nice to be able to close the player out when you are done listening to the player in the app like you can do in the original mobile plex app.
hold down the pause button.
wait, so I’m not sure if @sdguy21501 is on a Mac but the new 4.5.1 release actually is STUCK for me in a FULL WINDOW mode locked in position, with no way to escape that dimension. I don’t even have the GREEN full screen option to get rid of Full screen. I don’t even think PlexAmp thinks it’s aware that it’s doing this. I downloaded Magnet app to see if Magnet as a window manager could override Plexamp 4.5.1 and resize it to anything I tell it but PlexAmp refuses to do anything. I even went on to double check my settings in Plexamp and nothing is showing that its related to LOCKING the window size down to FULL SCREEN. This is most likely a separate situation than what OP is dealing with but I’d thought I’d let you know @elan that PlexAmp 4.5.1 is have an issue.
Elan - never mind, I fixed my issue by going into the MainWindow.json file and discovered that FullScreen was set to True and changed it to False. My issue is fixed.
I didn’t know you could do that. Thanks!
