How to configure rasplex through ssh (Without Screen) ?
Hello everyone,
I’am setting up a rasplex headless client to stream music through my hifi system.
I have a raspberry B+ with a hifiberry DAC but no hdmi monitor or tv.
I successfully configured wifi through ssh using connmanctl and I can see the client using plex/Web but nothing is playing and I don’t know how to select the soundcard using ssh. (I already activated hifiberry in the config.txt)
Is there any way to configure rasplex through ssh ?
Thank you !
Not really, you need to connect the RPi to a monitor on first boot and set the HiFiBerry as audio output device (second option) and other preferences and System Settings, you can then disconnect and control it via other clients.
Regards.
