How to connect Serenity on Nvidia Shield TV
Plex Media Server is installed on Nvidia Shield TV, i use Shield TV as Plex Server and i tried
to get access with Serenity for Android
but i get error like this
“unable to connect to ipadress”
does Serenity not work when the Plex Server
is installed on Shield TV ?
i searched everywhere in the internet for a tut
how to cannect Serenity with Shield TV
but there are nothing i couldnt find
hope someone can explain me how to connect
İt to Shield TV i need it for the External Player option…
Thanks for all the answer
Nobody has a idea ?
I haven’t tried installing it on the Shield. It should auto detect the IP address. If not, you should be able to set it to 127.0.0.1. Note you will probably need to disable the Security settings and Account sign in for Serenity to be able to see the server. Sorry for the late response I don’t get here as much as I should.
