How to delete servers from plex home user?
I have a plex home user that has 3 servers under it. I want to delete 2 and keep 1. The 2 I want to delete are no longer running (misconfiguration and decomissioned) and are no longer available
How can I do this?
Solution: Deleted and recreated user.
This has been solved.
urbanracer34,
You found-out yourself how to do that?
I having the same problem with a friend’s original/old server (now is the main server or the two) that we used to share & now, I need to remove from our Amazon Fire PLEX App… How were you able to do it?
Remove your own old servers: https://app.plex.tv/desktop#!/settings/devices/pms
Quit old servers which were shared with you: Some help (Revome Server from menu bar)
Tried that not option
Sorry, not sure I understand you.
It is not my servers, it is my friend’s, that shares his stuff with us, not the other way around.
Then the second of my links applies to your issue.
But when I have done that (through Web browser’s App.) already & just before this post it does not show the other server, which is currently the main server, through our TV.
Then it could be a caching problem.
On the tv, sign out from your plex account. then restart the tV and sign back in.
Or perhaps did you set the server IP address manually in the settings of the TV app? Some apps did allow that.
Did the first, but cannot do the second
OK, the radical method:
  • uninstall the Plex app from the TV
  • shut down the TV
  • unplug the TV from the mains for at least 5 minutes
  • reinstall the Plex app on the TV
